Zum Hauptinhalt wechseln
Repairing Detached Velcro Strap on a Backpack
Was du brauchst
  1. Repairing Detached Velcro Strap on a Backpack, Repairing Detached Velcro Strap on a Backpack: Schritt 1, Bild 1 von 2 Repairing Detached Velcro Strap on a Backpack, Repairing Detached Velcro Strap on a Backpack: Schritt 1, Bild 2 von 2
    • Using a pair of sharp scissors, carefully trim away any loose threads or frayed fabric from the strap and the material it was attached to.
  2. Repairing Detached Velcro Strap on a Backpack: Schritt 2, Bild 1 von 2 Repairing Detached Velcro Strap on a Backpack: Schritt 2, Bild 2 von 2
    • Clean the Velcro strap and the corresponding area on the backpack with a cloth dampened with mild soap and water.
    • Let both surfaces dry completely before moving to the next step.
  3. Repairing Detached Velcro Strap on a Backpack: Schritt 3, Bild 1 von 1
    • Apply a thin, even layer of fabric adhesive to the back of the Velcro strap.
    • Be sure to cover the entire surface, but avoid using so much glue that it seeps out from the edges.
  4. Repairing Detached Velcro Strap on a Backpack: Schritt 4, Bild 1 von 2 Repairing Detached Velcro Strap on a Backpack: Schritt 4, Bild 2 von 2
    • Let the Velcro and surrounding surfaces dry completely before moving to the next step.
  5. Repairing Detached Velcro Strap on a Backpack: Schritt 5, Bild 1 von 3 Repairing Detached Velcro Strap on a Backpack: Schritt 5, Bild 2 von 3 Repairing Detached Velcro Strap on a Backpack: Schritt 5, Bild 3 von 3
    • Measure and cut an 18-inch length of thread.
    • Thread one end of the thread through the eye of a sewing needle.
  6. Repairing Detached Velcro Strap on a Backpack: Schritt 6, Bild 1 von 3 Repairing Detached Velcro Strap on a Backpack: Schritt 6, Bild 2 von 3 Repairing Detached Velcro Strap on a Backpack: Schritt 6, Bild 3 von 3
    • Using your threaded needle, push the needle from the outside of the backpack fabric out through the inside of the reattached Velcro strap. Create several strong stitches back and forth to securely anchor the strap.
    • When finished, tie a secure knot on the inside of the fabric and trim the excess thread.
  7. Repairing Detached Velcro Strap on a Backpack: Schritt 7, Bild 1 von 3 Repairing Detached Velcro Strap on a Backpack: Schritt 7, Bild 2 von 3 Repairing Detached Velcro Strap on a Backpack: Schritt 7, Bild 3 von 3
    • Press the Velcro strap firmly onto its matching piece and pull it apart to ensure the bond is secure and the Velcro functions correctly.
Ziellinie
David Abraham
145 Reputation
1 Anleitung geschrieben
UC Davis, Team 2-9, Morris Fall 2025 Mitglied von UC Davis, Team 2-9, Morris Fall 2025
UCD-MORRIS-F25S2G9
2 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 42
Insgesamt: 164
