Einleitung
Stalled printer for error 0xF2 or 0xF3
This error happens when there are some problems with the encoder when the roller tries to move paper.
Was du brauchst
Remove the paper tray
Remove the paper cassette
Remove the ink tanks.
Clean the right encoder very gently with a dry tissue or a soft brush.
If you want to test the printer you need to insert paper, and cover 2 switches with tape.
Reassemble the printer (remove the tape first if you have used it) following these instructions in reverse.
16 weitere Nutzer:innen haben diese Anleitung absolviert.
14 Kommentare
Perfect. I used this guide to disassemble my printer.
I had 0xF1 and/or 0xF4. The reason was some paper stuck between the gears of the paper feed (in this guide step 12).
I hope this hint will help others. I didn't find any info about these error code online.
Error descriptions I found here - http://www.fatalerrors.info/
muito obrigado pela ajuda
