Zum Hauptinhalt wechseln
Repairing Gillette Mach 3 Disposable Razor Blade lubricated strip
Was du brauchst
  1. Repairing Gillette Mach 3 Disposable Razor Blade lubricated strip, Repairing Gillette Mach 3 Disposable Razor Blade lubricated strip: Schritt 1, Bild 1 von 1
    • Cut away the old (likely disintegrated) strip from the blade using a knife. Get a waterproof bandaid and cut 4 or 5 thin strips from the sticky part and layer them to make a new strip. Use the smooth-type bandage; not flexible fabric. Then sharpen by stropping on blue jeans. Voila! Shaves just like new. Blow dry after shaving to prevent rust.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
PartsIn
247 Reputation
1 Anleitung geschrieben
4 Kommentare
This is great! I'll have to try it. I'd love more information on how to sharpen the blades on blue jeans. How much stroking does it take to sharpen them? How do you tell when it's sharp enough?
Kyle Wiens - Antwort
Hey it takes about 15 to 20 strokes each way ( up and down) to maintain it. And 150 to 200 each way to re sharpen it. And when you can take off most of the hair on your arm in one pass its sharp enough
chase morris -
Yeah, a guide on "stopping" a razor would be great!
Daniel Beardsley - Antwort
Hi, I have a sterling silver razor handle with. Gillette blade housing. The housing is worn and does no longer supports the blade. Can I get a replacement top and switch it out with the broken one? Thanks Kevin
Kevin Locke - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 21
Letzte 30 Tage: 49
Insgesamt: 11,321
