Einleitung
This guide will show you how to clear out a paper jam in an HP OfficeJet 3833 series (HP OfficeJet 3830 series) printer. Occasionally, the paper will not feed into a printer or will feed incorrectly due to a paper jam. Foreign objects, such as thumbtacks and push pins, can get stuck inside the paper feeder and cause a paper jam. This guide will also show you how to locate unwanted blockages from the printer.
It is imperative to follow steps 5-6 to make sure to power is turned off correctly and disconnected from any external power source.
Was du brauchst
Check the input tray, located in the back of the printer, for any paper remains and remove them.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Check the input tray for any foreign objects.
Check the output tray, located in the front of the printer, for paper remains and remove them.
Shut down the printer.
Hold down the power button until a message appears.
Select the Shut Down option.
Unplug the printer power cable from the wall outlet.
Remove the power cable from the back of the printer.
Pull back on the front sides of the printer to remove the front panel.
Then pull the handle inside to remove the ink cartridge panel.
Locate the cleanout door on the bottom half of the printer.
Open the cleanout door to remove unwanted debris.
