Zum Hauptinhalt wechseln
Repairing HP Photosmart D110a Paper Jam
  1. Repairing HP Photosmart D110a Paper Jam, Repairing HP Photosmart D110a Paper Jam: Schritt 1, Bild 1 von 1
    • Identify the location where the piece of paper is jammed.
  2. Repairing HP Photosmart D110a Paper Jam: Schritt 2, Bild 1 von 3 Repairing HP Photosmart D110a Paper Jam: Schritt 2, Bild 2 von 3 Repairing HP Photosmart D110a Paper Jam: Schritt 2, Bild 3 von 3
    • Use your hand to gently remove the jammed paper.
    • Pull the paper until it is completely removed from the printer.
  3. Repairing HP Photosmart D110a Paper Jam: Schritt 3, Bild 1 von 1
    • Dispose of paper that caused the jam. Replace the jammed paper with fresh, unwrinkled paper.
Ziellinie
Tim Wise
173 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 10-38, Forte Spring 2011 Mitglied von Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
5 Mitglieder
10 Anleitungen geschrieben
3 Kommentare
my printer is jamming overtime I try to print something. I have cleared paper jams from both the front and back, and it’s still doing it. Any ideas?
Lissa barrett - Antwort
My D110a printer sometimes does this depending on the paper thickness. Thin paper jams more than thick paper, so I suspect that the rollers are getting slick and cannot grab the paper. I will try to open my own unit and see if they can be cleaned or recondition to eliminate the problem. I will post again if I can fix it!
raymondjram -
The paper can be removed from the rear. The roller cover is removed by puling out the cover on the left side (as seen from the rear) and slides toward the left. The paper ca n be grabbed by hand. To replace the cover, slide the two plastic pins inward toward the right until they catch, then push the cover back from the left side.
raymondjram - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 11
Insgesamt: 4,590
