Zum Hauptinhalt wechseln
Einleitung
Needed remedies:
- Screwdrivers
- Brush
- Oil
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove battery
    • Remove battery
    • Turn Netbook upside down
    • Unscrew all screws from the back of the pc
    • Remove the back plate
    • Unscrew metal cover on top of fan
  2. Gently lift the fan making sure not to drop dust into the motor of the fan below Clean fan blades Clean the fan house
    • Gently lift the fan making sure not to drop dust into the motor of the fan below
    • Clean fan blades
    • Clean the fan house
    • place the fan upside down so the metal pin points upwards
  3. Apply oil
    • Apply oil
    • Apply one or two droplets of oil onto the metal pin
    • Place it on the motor and make sure it rotates without problems
    • In case there is still sounds coming from the fan when turned on, redo the cleaning and lubrication.
    • Assemble everything and test
Abschluss
9 weitere Nutzer haben diese Anleitung absolviert.
Knud
377 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 4,149
