Zum Hauptinhalt wechseln
Repairing Oster 6344 Toaster Lever
Was du brauchst
  1. Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: Schritt 1, Bild 1 von 3 Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: Schritt 1, Bild 2 von 3 Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: Schritt 1, Bild 3 von 3
    • Assure the toaster is unplugged.
  2. Repairing Oster 6344 Toaster Lever: Schritt 2, Bild 1 von 2 Repairing Oster 6344 Toaster Lever: Schritt 2, Bild 2 von 2
    • Look down into the bread slots and assure that the metal tongues are not bent or crooked.
    • If the metal tongues are bent use the pliers to straighten them.
    • Plug your toaster back in and test it to see if the lever stays down.
  3. Repairing Oster 6344 Toaster Lever: Schritt 5, Bild 1 von 1
    • (Optional): To clean the toaster, make sure it is unplugged, empty the crumb tray and then clean out all visible residue.
    • Note: Compressed air, wooden skewers, and slightly damp, lint free cloths are most helpful when cleaning your toaster.
    • Be sure that the toaster is completely dry from cleaning before you reassemble it.
Abschluss
Daniel
109 Reputation
1 Anleitung geschrieben
UC Santa Barbara, Team 2-6, Bradley Spring 2013 Mitglied von UC Santa Barbara, Team 2-6, Bradley Spring 2013
UCSB-BRADLEY-S13S2G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 1,628
