Zum Hauptinhalt wechseln
Repairing Paper Jam
  1. Repairing Paper Jam, Drum Unit and Toner Cartridge: Schritt 1, Bild 1 von 1
    • Press the front cover release button.
    • Keep the button pressed and pull the cover toward yourself.
  2. Repairing Paper Jam: Schritt 2, Bild 1 von 3 Repairing Paper Jam: Schritt 2, Bild 2 von 3 Repairing Paper Jam: Schritt 2, Bild 3 von 3
    • With the front cover in the downward position, the drum & toner unit will be visible.
    • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
  3. Repairing Paper Jam, Repairing Paper Jam: Schritt 3, Bild 1 von 2 Repairing Paper Jam, Repairing Paper Jam: Schritt 3, Bild 2 von 2
    • DO NOT TOUCH the electrodes on the right inner wall of the printer. Touching these electrodes can cause electrical damage to the printer.
  4. Repairing Paper Jam, Paper Jam Type 1: Schritt 4, Bild 1 von 3 Repairing Paper Jam, Paper Jam Type 1: Schritt 4, Bild 2 von 3 Repairing Paper Jam, Paper Jam Type 1: Schritt 4, Bild 3 von 3
    • If jammed, paper will be visible after removing the drum unit. To clear paper jam, reach into printer and grab a corner of the paper.
    • Proceed to lift paper up and out of the printer.
    • Jammed paper may require an excess amount of force to be removed from printer.
  5. Repairing Paper Jam, Paper Jam Type 2: Schritt 5, Bild 1 von 2 Repairing Paper Jam, Paper Jam Type 2: Schritt 5, Bild 2 von 2
    • Grab onto the lift located on the paper tray near the bottom on the front of the printer.
    • Pull the paper tray completely out of the printer by pulling towards yourself.
  6. Repairing Paper Jam: Schritt 6, Bild 1 von 2 Repairing Paper Jam: Schritt 6, Bild 2 von 2
    • If jammed paper is visible, grab onto the paper and remove by pulling up and towards yourself.
    • Jammed paper may require a large amount of force to be removed from printer.
  7. Repairing Paper Jam, Paper Jam Type 3: Schritt 7, Bild 1 von 3 Repairing Paper Jam, Paper Jam Type 3: Schritt 7, Bild 2 von 3 Repairing Paper Jam, Paper Jam Type 3: Schritt 7, Bild 3 von 3
    • Located on the back of the printer, open up the cover by grabbing onto the tab and pulling down.
  8. Repairing Paper Jam: Schritt 8, Bild 1 von 3 Repairing Paper Jam: Schritt 8, Bild 2 von 3 Repairing Paper Jam: Schritt 8, Bild 3 von 3
    • In front of you will see two blue tabs, one on the left and right side.
    • First, push the top part of the tab in until the bottom part of the tab lifts up.
    • Grab onto the bottom part of the tab.
  9. Repairing Paper Jam: Schritt 9, Bild 1 von 2 Repairing Paper Jam: Schritt 9, Bild 2 von 2
    • Once you have a firm grib of both the right and left tab, lift both tabs up and towards yourself.
    • The fuser cover, which the tabs are connected to, does not come completely out of the printer because it is attached to the bottom by a hinge.
  10. Repairing Paper Jam: Schritt 10, Bild 1 von 3 Repairing Paper Jam: Schritt 10, Bild 2 von 3 Repairing Paper Jam: Schritt 10, Bild 3 von 3
    • If jammed paper is visible, grab onto the top of the paper and pull up until completely removed from printer.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Nathan Ruiz
165 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 4-14, Forte Winter 2010 Mitglied von Cal Poly, Team 4-14, Forte Winter 2010
CPSU-FORTE-W10S4G14
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 26
Insgesamt: 14,000
