Zum Hauptinhalt wechseln
Repairing Philips GoGear SA3245 2 Battery and Frozen screen
Was du brauchst
  1. Repairing Philips GoGear SA3245 2 Battery and Frozen screen, Battery and Frozen svreen: Schritt 1, Bild 1 von 2 Repairing Philips GoGear SA3245 2 Battery and Frozen screen, Battery and Frozen svreen: Schritt 1, Bild 2 von 2
    • Find the screw under the S/N Label
  2. Repairing Philips GoGear SA3245 2 Battery and Frozen screen: Schritt 2, Bild 1 von 2 Repairing Philips GoGear SA3245 2 Battery and Frozen screen: Schritt 2, Bild 2 von 2
    • Slide the metal panel
    • It is slightly difficult
  3. Repairing Philips GoGear SA3245 2 Battery and Frozen screen: Schritt 3, Bild 1 von 2 Repairing Philips GoGear SA3245 2 Battery and Frozen screen: Schritt 3, Bild 2 von 2
    • Remove the two screws at the top left and right of the unit.
  4. Repairing Philips GoGear SA3245 2 Battery and Frozen screen: Schritt 4, Bild 1 von 1
    • Carefully remove the front panel
  5. Repairing Philips GoGear SA3245 2 Battery and Frozen screen: Schritt 5, Bild 1 von 2 Repairing Philips GoGear SA3245 2 Battery and Frozen screen: Schritt 5, Bild 2 von 2
    • Insert wisdom here.
  6. Repairing Philips GoGear SA3245 2 Battery and Frozen screen: Schritt 6, Bild 1 von 3 Repairing Philips GoGear SA3245 2 Battery and Frozen screen: Schritt 6, Bild 2 von 3 Repairing Philips GoGear SA3245 2 Battery and Frozen screen: Schritt 6, Bild 3 von 3
    • Remove this 3 screws
  7. Repairing Philips GoGear SA3245 2 Battery and Frozen screen: Schritt 7, Bild 1 von 3 Repairing Philips GoGear SA3245 2 Battery and Frozen screen: Schritt 7, Bild 2 von 3 Repairing Philips GoGear SA3245 2 Battery and Frozen screen: Schritt 7, Bild 3 von 3
    • Carefully remove the motherboard with display
  8. Repairing Philips GoGear SA3245 2 Battery and Frozen screen: Schritt 8, Bild 1 von 2 Repairing Philips GoGear SA3245 2 Battery and Frozen screen: Schritt 8, Bild 2 von 2
    • This is a defective battery. Replace it with a new one.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
ialexandroo
225 Reputation
2 Anleitungen geschrieben
Ein Kommentar
where would you even get a battery?
Liam Sheldon - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 48
Insgesamt: 3,565
