Zum Hauptinhalt wechseln
Repairing Polaroid Sun 600 LMS Gear Train
Was du brauchst
  1. Repairing Polaroid Sun 600 LMS Gear Train, Open film door: Schritt 1, Bild 1 von 2 Repairing Polaroid Sun 600 LMS Gear Train, Open film door: Schritt 1, Bild 2 von 2
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Repairing Polaroid Sun 600 LMS Gear Train: Schritt 2, Bild 1 von 1
    • Locate small silver gear in top left corner of film bay.
  3. Repairing Polaroid Sun 600 LMS Gear Train: Schritt 3, Bild 1 von 1
    • Using a plastic opening tool, rotate gear downward until jam is cleared.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Matthew Lessig
63 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 3-18, Maness Winter 2010 Mitglied von Cal Poly, Team 3-18, Maness Winter 2010
CPSU-MANESS-W10S3G18
4 Mitglieder
4 Anleitungen geschrieben
3 Kommentare
How do you know if the jam is cleared ? I have the same camera but the problem with mine is the shutter button. Every time I press the red and black one it won't make the noise or spit out the film unless I go one button behind. Although when I do that the photo comes out black. I think the two buttons or supposed to be together so when you press the red and black button the one behind it moves in sync. I really need help on fixing it and I'm not sure if what I said made any sense but I need help.
Tiffany - Antwort
I have this very same problem…You explained it perfectly, however, I can’t figure out how to fix it. Please someone help us!
Jordan Brown -
Currently trying to fix it but after the steps it isn’t working. How do I know how many times to turn the gear?
Eleanor Murphy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 6
Letzten 30 Tage: 51
Insgesamt: 8,495
