Zum Hauptinhalt wechseln
Repairing Quasar Microwave Sparking Inside
Was du brauchst
  1. Repairing Quasar Microwave Sparking Inside, Disassembling Quasar Microwave Outer Cover: Schritt 1, Bild 1 von 1
    • Disconnect the power supply cord from the outlet.
  2. Repairing Quasar Microwave Sparking Inside: Schritt 2, Bild 1 von 2 Repairing Quasar Microwave Sparking Inside: Schritt 2, Bild 2 von 2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Repairing Quasar Microwave Sparking Inside: Schritt 3, Bild 1 von 2 Repairing Quasar Microwave Sparking Inside: Schritt 3, Bild 2 von 2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Repairing Quasar Microwave Sparking Inside: Schritt 4, Bild 1 von 3 Repairing Quasar Microwave Sparking Inside: Schritt 4, Bild 2 von 3 Repairing Quasar Microwave Sparking Inside: Schritt 4, Bild 3 von 3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
  5. Repairing Quasar Microwave Sparking Inside, Sparking: Schritt 5, Bild 1 von 1
    • First check to see if the interior of the microwave is dirty. Food or tin foil could be the reason that the microwave is sparking.
    • If the interior of the microwave is dirty, clean it. A spotless interior is recommended. The interior should look like the example in the picture.
  6. Repairing Quasar Microwave Sparking Inside: Schritt 6, Bild 1 von 1
    • If the microwave continues to spark after the interior has been cleaned, that could indicate that the diode may be broken. The diode is what attaches the capacitor to the back of the microwave.
    • A multimeter can be used to measure the resistance of the diode. The multimeter must be on the resistance setting or the diode check setting. If the diode reads zero in both directions, then it is broken.
  7. Repairing Quasar Microwave Sparking Inside: Schritt 7, Bild 1 von 1
    • Sparking inside of the microwave may also be the result of a broken or misaligned magnetron. If this is the case, it is recommended to take the microwave to a qualified professional or completely discarding the unit and purchasing a new one.
    • Fixing the magnetron without the aid of a qualified professional is NOT recommended. The magnetron is an emitter of microwave radiation and tampering with it may lead to serious injury or death.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Michael
222 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 2-12, Propen Fall 2012 Mitglied von Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Is the magnetron the failing component if you have this microwave or perhaps a 1983-1985 model quasar brand and the microwave doesn’t turn on after hitting “start”, a timer goes but no microwave heating is engaged?
Eric Ouyang - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 35
Insgesamt: 4,318
