Zum Hauptinhalt wechseln
  1. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
    • Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
  2. Remove back cover with plastic opening tool, exposing the battery and motherboard. Remove back cover with plastic opening tool, exposing the battery and motherboard. Remove back cover with plastic opening tool, exposing the battery and motherboard.
    • Remove back cover with plastic opening tool, exposing the battery and motherboard.
  3. Uncoil the wires. If necessary, use a wire stripper to expose more of the wire.
    • Uncoil the wires. If necessary, use a wire stripper to expose more of the wire.
  4. Solder the wires to the base of the speaker. The metal of the wire should be touching exposed metal on the speaker. Insure that the colors of the wires match the picture. Solder the wires to the base of the speaker. The metal of the wire should be touching exposed metal on the speaker. Insure that the colors of the wires match the picture.
    • Solder the wires to the base of the speaker. The metal of the wire should be touching exposed metal on the speaker. Insure that the colors of the wires match the picture.
Abschluss
Matthew Wills
444 Reputation
4 Anleitungen geschrieben
Clemson, Team 14-4, Shirley Spring 2015 Mitglied von Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Mitglieder
15 Anleitungen geschrieben
I can't hear anything on this tablet, never have... I also only have a camera lens on one side of this thing.... Do I have a faulty tablet?
lindamtasa - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 737
