Zum Hauptinhalt wechseln
Einleitung
This guide will enable you to replace the keypad in a Samsung SPH-A640 phone.
  1. Press and hold the “End” button until the phone powers off.
    • Press and hold the “End” button until the phone powers off.
  2. Turn the phone over on its backside. Remove the bottom cover by sliding it downward, and then remove the battery.
    • Turn the phone over on its backside.
    • Remove the bottom cover by sliding it downward, and then remove the battery.
  3. Using a #00 Phillips screwdriver, remove  four screws from the bottom half of the phone in the battery compartment. Place screws off to the side.
    • Using a #00 Phillips screwdriver, remove four screws from the bottom half of the phone in the battery compartment. Place screws off to the side.
  4. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  5. Using spudger, pry off back cover starting at the bottom corners and moving  around the perimeter towards the hinge. Disengaging the clips near the hinge may require some force.
    • Using spudger, pry off back cover starting at the bottom corners and moving around the perimeter towards the hinge. Disengaging the clips near the hinge may require some force.
  6. Using tweezers, carefully remove buttons from both sides while removing back cover.  Note the positions of the buttons. They must be returned to the proper positions.
    • Using tweezers, carefully remove buttons from both sides while removing back cover. Note the positions of the buttons. They must be returned to the proper positions.
  7. Using spudger, disconnect electrical connector near the hinge.
    • Using spudger, disconnect electrical connector near the hinge.
  8. Using flathead screwdriver, lift motherboard away and remove from phone.
    • Using flathead screwdriver, lift motherboard away and remove from phone.
  9. Lift, remove and replace key pad.
    • Lift, remove and replace key pad.
Abschluss
Natasha
1 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-2, Meza Spring 2014 Mitglied von Ohio State, Team 1-2, Meza Spring 2014
OSU-MEZA-S14S1G2
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
Insgesamt: 144
