Einleitung
Samsung WF361BVBEWR A1 3.6 Cu. Ft. Capacity 8-Cycle High-Efficiency Front-Loading Washer With Internal Water Heater will sometimes get a ND, Not Draining, error code. Here is a guide to help you clear it.
Remove filter from the lower left corner on the front of the washer
Wash debris from filter and reinstall. Once clean the washer should drain properly.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
