Zum Hauptinhalt wechseln
Repairing Sony Xperia L Volume Control Button
Was du brauchst
  1. Repairing Sony Xperia L Volume Control Button, Open the phone case: Schritt 1, Bild 1 von 3 Repairing Sony Xperia L Volume Control Button, Open the phone case: Schritt 1, Bild 2 von 3 Repairing Sony Xperia L Volume Control Button, Open the phone case: Schritt 1, Bild 3 von 3
    • The Xperia L model
    • Gently open the phone case.
    • The phone body, back case and the detached volume control button.
  2. Repairing Sony Xperia L Volume Control Button, Adjust the plastic notches using the plastic opening tools.: Schritt 2, Bild 1 von 2 Repairing Sony Xperia L Volume Control Button, Adjust the plastic notches using the plastic opening tools.: Schritt 2, Bild 2 von 2
    • Using the plastic opening tools in the iFixit kit, pull up the flattened plastic notches that will hold the volume control button in place.
    • You can see the notches on the back case and the holes in the volume control button that snap fit in them.
  3. Repairing Sony Xperia L Volume Control Button, Place the button and snap it to the back case using the raised notches.: Schritt 3, Bild 1 von 2 Repairing Sony Xperia L Volume Control Button, Place the button and snap it to the back case using the raised notches.: Schritt 3, Bild 2 von 2
    • Place the volume control button back in the slot.
    • Adjust the holes on the button in a way that they snap to the raised notches on the back panel.
    • Press down the raised plastic notches using the back of the plastic opening tool from the kit.
  4. Repairing Sony Xperia L Volume Control Button, Snap the back case to the phone body.: Schritt 4, Bild 1 von 3 Repairing Sony Xperia L Volume Control Button, Snap the back case to the phone body.: Schritt 4, Bild 2 von 3 Repairing Sony Xperia L Volume Control Button, Snap the back case to the phone body.: Schritt 4, Bild 3 von 3
    • The volume control button is now attached in its slot.
    • Reassemble the phone back by snapping the back case to the phone body.
    • The volume control/zoom button is good to use!
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Ruchita
97 Reputation
1 Anleitung geschrieben
PIRL Gadget Garage Mitglied von PIRL Gadget Garage
Community
9 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 8
Letzte 30 Tage: 20
Insgesamt: 2,838
