Zum Hauptinhalt wechseln
Repairing TRITTON Kunai Left Speaker
Was du brauchst
  1. Repairing TRITTON Kunai Left Speaker, Repairing TRITTON Kunai Left Speaker: Schritt 1, Bild 1 von 2 Repairing TRITTON Kunai Left Speaker, Repairing TRITTON Kunai Left Speaker: Schritt 1, Bild 2 von 2
    • Grab the ear cushion between your thumb and finger.
    • Carefully pull the ear cushion away from the speaker frame until they separate.
  2. Repairing TRITTON Kunai Left Speaker: Schritt 2, Bild 1 von 2 Repairing TRITTON Kunai Left Speaker: Schritt 2, Bild 2 von 2
    • Use your Phillips #00 screwdriver to remove the two 9mm screws.
    • Use your Phillips #00 screwdriver to remove the two 7mm screws.
    • Remove the now detached black cover from the hinge frame.
  3. Repairing TRITTON Kunai Left Speaker: Schritt 3, Bild 1 von 2 Repairing TRITTON Kunai Left Speaker: Schritt 3, Bild 2 von 2
    • Use your Phillips #00 screwdriver to remove the two 7mm screws holding the bracket, headband, and hinge assembly together.
    • Seperate the bracket, headband, and speaker housing's hinge.
  4. Repairing TRITTON Kunai Left Speaker: Schritt 4, Bild 1 von 2 Repairing TRITTON Kunai Left Speaker: Schritt 4, Bild 2 von 2
    • Use your Phillips #00 screwdriver to remove the six 7mm screws holding the black speaker housing to the wiring housing.
    • Carefully separate the black speaker housing from the wiring housing.
    • Be gentle, the wires and solder points inside are fragile.
  5. Repairing TRITTON Kunai Left Speaker: Schritt 5, Bild 1 von 1
    • This is the circuit board for the USB connection to the speakers.
    • Inspect the five solder points for a broken wire connection. They are labeled SP-, M-, M+, R-, and R.
    • If any connections are broken, re-solder the wires. Use this image as a reference for correct wiring.
    • Carefully test the headset. Avoid touching the internals while the device is plugged in.
    • If your speaker is now working, skip to the conclusion.
    • Reinforcing the wires with electrical tape before reassembly is recommended.
  6. Repairing TRITTON Kunai Left Speaker: Schritt 6, Bild 1 von 1
    • This the back of the left ear speaker inside the black speaker housing.
    • The red wire connects to the leftmost terminal and the white wire connects to the rightmost terminal.
    • Inspect the red and white wires and two solder points for a broken connection to the speaker.
    • If your speaker is still not working, you may need to replace the speaker or USB circuit board. Please refer to the manufactures product specs from their website for further details.
Abschluss
To reassemble your device, follow steps 1 through 4 in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Timothy Meyer
155 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 3-3, Duarte Spring 2015 Mitglied von UMass Dartmouth, Team 3-3, Duarte Spring 2015
UMASSD-DUARTE-S15S3G3
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 1,489
