Zum Hauptinhalt wechseln
Repairing Tire Hole/Puncture
Was du brauchst
  1. Repairing Tire Hole/Puncture, Repairing Tire Hole/Puncture: Schritt 1, Bild 1 von 1
    • Wipe the surface of the tire with a rag to remove any loose dirt, rocks, or debris.
  2. Repairing Tire Hole/Puncture: Schritt 2, Bild 1 von 1
    • Using the air compressor, air the tire up to the original recommended weight for the vehicle.
    • Air is expected to continue to leak out so do not worry if you cannot get it perfect.
  3. Repairing Tire Hole/Puncture: Schritt 3, Bild 1 von 2 Repairing Tire Hole/Puncture: Schritt 3, Bild 2 von 2
    • Use the air pressure gauge to make sure the tire is now aired up to its original pressure.
  4. Repairing Tire Hole/Puncture: Schritt 4, Bild 1 von 1
    • Spray the surface of the tire completely with the soapy water.
  5. Repairing Tire Hole/Puncture: Schritt 5, Bild 1 von 1
    • Look for tiny air bubbles forming from the leaking air and soap combination, this is where the hole is located.
  6. Repairing Tire Hole/Puncture: Schritt 6, Bild 1 von 3 Repairing Tire Hole/Puncture: Schritt 6, Bild 2 von 3 Repairing Tire Hole/Puncture: Schritt 6, Bild 3 von 3
    • Once the hole is located, remove any foreign objects with the pliers if present.
    • Any object that is stuck in the tire, or puncturing the tire is considered a foreign object. These may include sharp objects, commonly seen as nails, screws, or pieces of metal.
  7. Repairing Tire Hole/Puncture: Schritt 7, Bild 1 von 1
    • Insert the reamer into the puncture.
    • Work the reamer in and out while twisting to clean and prep the puncture.
  8. Repairing Tire Hole/Puncture: Schritt 8, Bild 1 von 1
    • Put the plug into the insertion tool.
  9. Repairing Tire Hole/Puncture: Schritt 9, Bild 1 von 1
    • Insert the plug into the punctured area, leaving about ¼ inch of the plug above the surface of the tire.
    • Yank the insertion tool so the plug remains in the tire, but the tool releases.
    • Cut the remaining plug so it is flush with the tire.
  10. Repairing Tire Hole/Puncture: Schritt 10, Bild 1 von 1
    • Refill the tire to the proper pressure.
  11. Repairing Tire Hole/Puncture: Schritt 11, Bild 1 von 2 Repairing Tire Hole/Puncture: Schritt 11, Bild 2 von 2
    • Use the air pressure gauge to make sure that the tire is back to its original air pressure.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Missouri Western, Team 1-5, Adkins Fall 2015 Mitglied von Missouri Western, Team 1-5, Adkins Fall 2015
MWSU-ADKINS-F15S1G5
1 Mitglied
1 Anleitung geschrieben
Ein Kommentar
i work at discount tire and this is not a department of transportation approved fix and and repuidiple tire dealer will tell you they cannot put a tire back on if they notice this
redheadmateo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 28
Letzte 30 Tage: 92
Insgesamt: 5,380
