Zum Hauptinhalt wechseln
Repairing Tritton Kunai Speaker Buzzing Noise
Was du brauchst
  1. Repairing Tritton Kunai Speaker Buzzing Noise, Repairing Tritton Kunai Speaker Buzzing Noise: Schritt 1, Bild 1 von 2 Repairing Tritton Kunai Speaker Buzzing Noise, Repairing Tritton Kunai Speaker Buzzing Noise: Schritt 1, Bild 2 von 2
    • Remove the cushion of the speaker that the buzzing noise is occurring.
  2. Repairing Tritton Kunai Speaker Buzzing Noise: Schritt 2, Bild 1 von 3 Repairing Tritton Kunai Speaker Buzzing Noise: Schritt 2, Bild 2 von 3 Repairing Tritton Kunai Speaker Buzzing Noise: Schritt 2, Bild 3 von 3
    • Use the Philips PH00 screwdriver to unscrew the four screws located on the inner part of the rail adjustment.
  3. Repairing Tritton Kunai Speaker Buzzing Noise: Schritt 3, Bild 1 von 2 Repairing Tritton Kunai Speaker Buzzing Noise: Schritt 3, Bild 2 von 2
    • Remove the black metal bracket by unscrewing the two screws connecting it to the railing.
  4. Repairing Tritton Kunai Speaker Buzzing Noise: Schritt 4, Bild 1 von 2 Repairing Tritton Kunai Speaker Buzzing Noise: Schritt 4, Bild 2 von 2
    • Unscrew the screws in the locations shown to remove the speaker cover.
  5. Repairing Tritton Kunai Speaker Buzzing Noise: Schritt 5, Bild 1 von 1
    • Place the black cover to the side, near the rest of the setup.
  6. Repairing Tritton Kunai Speaker Buzzing Noise: Schritt 6, Bild 1 von 2 Repairing Tritton Kunai Speaker Buzzing Noise: Schritt 6, Bild 2 von 2
    • Observe the wire orientation: The red metal wire should be to the far left, while the green metal wire should be next to it, the skinny red rubber wire should be second to the right, and the thick red rubber wire should be to the far right. If any of the wires are out of place fasten them into their proper positions.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 3-3, Duarte Spring 2015 Mitglied von UMass Dartmouth, Team 3-3, Duarte Spring 2015
UMASSD-DUARTE-S15S3G3
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 2,213
