Einleitung
Learn how to stop the buzzing and bring back clear sound on your headset.
Was du brauchst
Remove the cushion of the speaker that the buzzing noise is occurring.
Use the Philips PH00 screwdriver to unscrew the four screws located on the inner part of the rail adjustment.
Remove the black metal bracket by unscrewing the two screws connecting it to the railing.
Observe the wire orientation: The red metal wire should be to the far left, while the green metal wire should be next to it, the skinny red rubber wire should be second to the right, and the thick red rubber wire should be to the far right. If any of the wires are out of place fasten them into their proper positions.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
