Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide required
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a Phillips #1 screwdriver, remove the 4.8mm Phillips #1 screw on the battery cover by twisting the screwdriver counter-clockwise. Using a Phillips #1 screwdriver, remove the 4.8mm Phillips #1 screw on the battery cover by twisting the screwdriver counter-clockwise.
    • Using a Phillips #1 screwdriver, remove the 4.8mm Phillips #1 screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. Then simply remove the two AAA batteries by pulling on one end of the battery and lifting it straight out. Then simply remove the two AAA batteries by pulling on one end of the battery and lifting it straight out. Then simply remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
    • Then simply remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. Take care when you want to close it. There is a notch. First you have to hook up that notch. Then firmly use a PH1 screwdriver to secure it.
    • Take care when you want to close it. There is a notch.
    • First you have to hook up that notch.
    • Then firmly use a PH1 screwdriver to secure it.
  4. Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver. Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
    • Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
  5. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  6. Removed 1 4.8mm phillips head screw with a #0 Phillips head screw driver and lift away battery pack being conscientious of wires. Removed 1 4.8mm phillips head screw with a #0 Phillips head screw driver and lift away battery pack being conscientious of wires. Removed 1 4.8mm phillips head screw with a #0 Phillips head screw driver and lift away battery pack being conscientious of wires.
    • Removed 1 4.8mm phillips head screw with a #0 Phillips head screw driver and lift away battery pack being conscientious of wires.
  7. Remove 2 7.2mm phillips head screws with a #0 Phillips head screw driver. Once the screws have been removed slide off the spring.
    • Remove 2 7.2mm phillips head screws with a #0 Phillips head screw driver.
    • Once the screws have been removed slide off the spring.
  8. Removed 1 7.5mm phillips screw with a #0 Phillips screw driver. Once the screw has been removed lift up the black plastic piece. Once the screw has been removed lift up the black plastic piece.
    • Removed 1 7.5mm phillips screw with a #0 Phillips screw driver.
    • Once the screw has been removed lift up the black plastic piece.
  9. Remove 4 7.5mm Phillips head screws with a #0 Phillips screw driver. Remove 4 7.5mm Phillips head screws with a #0 Phillips screw driver.
    • Remove 4 7.5mm Phillips head screws with a #0 Phillips screw driver.
  10. Remove the two buttons, noting how wires are placed for reassembly. Remove the two buttons, noting how wires are placed for reassembly.
    • Remove the two buttons, noting how wires are placed for reassembly.
  11. Lift the button board up and away to clear room for lifting motherboard. Tilt assembly up but being wary that it is still attached to front panel.
    • Lift the button board up and away to clear room for lifting motherboard.
    • Tilt assembly up but being wary that it is still attached to front panel.
  12. Slide the toothed slider towards you to remove.
    • Slide the toothed slider towards you to remove.
  13. First with the toothed slider removed align the two black lines together by moving the belt back and forth.
    • First with the toothed slider removed align the two black lines together by moving the belt back and forth.
    • Once aligned reinsert the toothed slider at the exact point shown.
Abschluss
To reassemble your device, follow these instructions in reverse order, skipping step 10 as the toothed slider has already been put in for proper alignment.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Sean Webb
384 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 2-4, Sullivan Fall 2015 Mitglied von USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
3 Mitglieder
6 Anleitungen geschrieben
Good work !
Nice.
I did not see the black line in mine,
i opened the foil and glued it new together . Not so nice. :D
But it works.
Schwarzstein - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 9
Insgesamt: 985
