Zum Hauptinhalt wechseln
Repairing VTech Touch and Swipe Baby Phone Screen Alignment
Was du brauchst
  1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: Schritt 1, Bild 1 von 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: Schritt 1, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
    Frag FixBot
    Kommentar hinzufügen
  2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 2, Bild 1 von 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 2, Bild 2 von 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 2, Bild 3 von 3
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
    Frag FixBot
  3. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 3, Bild 1 von 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 3, Bild 2 von 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 3, Bild 3 von 3
    • When reassembling, align the notch on the battery panel with the slot on the phone.
    Frag FixBot
  4. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 4, Bild 1 von 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 4, Bild 2 von 2
    • Remove four 13.8mm screws from the back of the device using a Phillips #1 screwdriver.
    Frag FixBot
  5. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 5, Bild 1 von 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 5, Bild 2 von 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 5, Bild 3 von 3
    • Remove a single 4.8 mm screw with a Phillips #0 screwdriver and lift away the battery pack being careful of the wires.
    Frag FixBot
  6. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 6, Bild 1 von 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 6, Bild 2 von 2
    • Remove two 7.2 mm screws with a Phillips #0 screwdriver.
    • Slide off the spring.
    Frag FixBot
  7. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 7, Bild 1 von 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 7, Bild 2 von 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 7, Bild 3 von 3
    • Remove the single 7.5mm screw with a Phillips #0 screwdriver.
    • Lift up the black plastic piece.
    Frag FixBot
  8. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 8, Bild 1 von 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 8, Bild 2 von 2
    • Remove four 7.5mm screws with a Phillips #0 screwdriver.
    Frag FixBot
  9. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 9, Bild 1 von 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 9, Bild 2 von 2
    • Remove the two buttons, noting how wires are placed for reassembly.
    Frag FixBot
  10. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 10, Bild 1 von 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 10, Bild 2 von 2
    • Lift the button board up and away to clear room for lifting the motherboard.
    • Tilt the assembly up but being wary that it is still attached to the front panel.
    Frag FixBot
  11. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 11, Bild 1 von 1
    • Slide the toothed slider towards you to remove.
    Frag FixBot
  12. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: Schritt 12, Bild 1 von 1
    • To reassemble, align the two black lines together by moving the belt back and forth.
    • Once aligned reinsert the toothed slider at the exact point shown.
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order, skipping step 10 as the toothed slider has already been put in for proper alignment.
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 2-4, Sullivan Fall 2015 Mitglied von USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
3 Mitglieder
12 Anleitungen geschrieben
1 Kommentar zur Anleitung
Good work !
Nice.
I did not see the black line in mine,
i opened the foil and glued it new together . Not so nice. :D
But it works.
Schwarzstein - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 55
Insgesamt: 1,862
