Zum Hauptinhalt wechseln
Repairing a Broken Ceramic Pot
Was du brauchst
  1. Repairing a Broken Ceramic Pot, Repairing a Broken Ceramic Pot: Schritt 1, Bild 1 von 1
    • Gather all fragmented pieces of the broken pot.
    • Caution: Be careful handling broken pieces. Edges might be sharp.
  2. Repairing a Broken Ceramic Pot: Schritt 2, Bild 1 von 1
    • Assemble each fragment of the pot temporarily to understand where each piece goes.
  3. Repairing a Broken Ceramic Pot: Schritt 3, Bild 1 von 1
    • Clean the edges of the pot and its fragments with a clean cloth or paper towel.
  4. Repairing a Broken Ceramic Pot: Schritt 4, Bild 1 von 1
    • Apply a small amount of Waterproof Gorilla Glue to the edges of the broken pot.
    • Gorilla Glue recommends 1 dot per square inch.
    • Caution: Do not touch glue with fingers. Wear gloves for extra precaution.
  5. Repairing a Broken Ceramic Pot: Schritt 5, Bild 1 von 2 Repairing a Broken Ceramic Pot: Schritt 5, Bild 2 von 2
    • Carefully fit the fragmented piece along the glued area and hold it firmly for 10-45 seconds.
  6. Repairing a Broken Ceramic Pot: Schritt 6, Bild 1 von 1
    • Glue the inside of the pot for extra coverage and hold.
    • Repeat this process for other broken pieces, if any.
  7. Repairing a Broken Ceramic Pot: Schritt 7, Bild 1 von 1
    • Let the glue set for at least 24 hours.
Abschluss
Repeat steps as needed until your pot is fully reassembled.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Christina Liles
145 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 54
Letzte 30 Tage: 249
Insgesamt: 5,816
