Zum Hauptinhalt wechseln
Repairing a Wobbly Piano Bench
Was du brauchst
    1. Repairing a Wobbly Piano Bench, Repairing a Wobbly Piano Bench: Schritt 1, Bild 1 von 1
      • Place the bench on an even surface.
      Frag FixBot
      Kommentar hinzufügen
    2. Repairing a Wobbly Piano Bench: Schritt 2, Bild 1 von 1
      • Open and lock its lid. Make sure it stays open during the whole procedure.
      Frag FixBot
    3. Repairing a Wobbly Piano Bench: Schritt 3, Bild 1 von 3 Repairing a Wobbly Piano Bench: Schritt 3, Bild 2 von 3 Repairing a Wobbly Piano Bench: Schritt 3, Bild 3 von 3
      • Unscrew the outer hex nut from one leg using the wrench and take the lock washer out.
      Frag FixBot
    4. Repairing a Wobbly Piano Bench: Schritt 4, Bild 1 von 3 Repairing a Wobbly Piano Bench: Schritt 4, Bild 2 von 3 Repairing a Wobbly Piano Bench: Schritt 4, Bild 3 von 3
      • Take the leg out and unscrew the inner hex nut.
      • Replace the washers with the new ones and re-screw the hex nut tightly.
      Frag FixBot
    5. Repairing a Wobbly Piano Bench: Schritt 5, Bild 1 von 1
      • Connect the leg to the bench again using the new lock washer.
      • Screw the hex nut a few rounds, but do not tighten it yet.
      • Repeat Steps 3 through 5 for all four legs.
      Frag FixBot
    6. Repairing a Wobbly Piano Bench: Schritt 6, Bild 1 von 2 Repairing a Wobbly Piano Bench: Schritt 6, Bild 2 von 2
      • Add a little weight to the chair or push it down with two hands.
      • Turn all four outer hex nuts one round.
      • Make sure the bench is balanced and repeat until all hex nuts are tight.
      Frag FixBot
    7. Repairing a Wobbly Piano Bench: Schritt 7, Bild 1 von 2 Repairing a Wobbly Piano Bench: Schritt 7, Bild 2 von 2
      • Close the lid seat on the chair.
      • If the chair is not balanced or if it makes noises, unscrew the outer nut two rounds and repeat Step 6.
      Frag FixBot
Abschluss
You can redo this process every 6 months to make sure your bench is always stable.
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 38
Insgesamt: 1,800
