Einleitung
This guide teaches you how to repair and replace the cooling fan on the Dell Inspiron 15-7560 laptop.
Was du brauchst
Power off the laptop and place the laptop with the bottom facing upwards.
Remove eight 5 mm screws from the bottom of the laptop.
Loosen the three captive screws.
Use an iFixit opening tool to pry the bottom cover away from the laptop.
Remove the black insulating tape from the fan connector.
Pinch the sides of the white fan connector with your thumb and index fingernail and pull it out of its socket.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
