Einleitung
This guide will walk you through our repair process step by step on how to reattach a loose nose pad on a pair of eyeglasses. You will need a nose pad, a 1.0mm flathead screwdriver, a magnet, and an extra screw if you have lost the one on your eyeglasses.
We feel this guide is necessary because according to our research, myopia is affecting nearly 40 percent of the US population. In addition, based on our own experiences, nose pads are normally the weakest part of the glasses. For those who need their glasses every day, knowing how to repair the nose pads by themselves is extremely useful.
Was du brauchst
Insert the nose pad into the mount on the frame.
While holding the nose pad in place, use the magnet to attract the screw head.
Holding the glasses with the screw head pointing up, tighten the screw with the screwdriver.
3 weitere Personen haben diese Anleitung absolviert.
