Zum Hauptinhalt wechseln
Repairing the Proline Guitar Strap Lock Spring
Was du brauchst
  1. Repairing the Proline Guitar Strap Lock Spring, Repairing the Proline Guitar Strap Lock Spring: Schritt 1, Bild 1 von 3 Repairing the Proline Guitar Strap Lock Spring, Repairing the Proline Guitar Strap Lock Spring: Schritt 1, Bild 2 von 3 Repairing the Proline Guitar Strap Lock Spring, Repairing the Proline Guitar Strap Lock Spring: Schritt 1, Bild 3 von 3
    • To take apart the strap lock, take the black ball cap and turn it counterclockwise.
    • After you unscrew the ball cap, pull on the other side of the locking mechanism (opposite to the ball cap) to remove the spring and bar.
    • Unlock your strap lock from the guitar before attempting this step.
  2. Repairing the Proline Guitar Strap Lock Spring: Schritt 2, Bild 1 von 2 Repairing the Proline Guitar Strap Lock Spring: Schritt 2, Bild 2 von 2
    • You should have these two parts removed from the rest of the lock mechanism.
    • If you do not have the spring or your spring is broken, you can get the spring described in the conclusion.
    • In a pinch: a spring from some pens, cut to length, can act as the spring in your strap lock.
  3. Repairing the Proline Guitar Strap Lock Spring: Schritt 3, Bild 1 von 2 Repairing the Proline Guitar Strap Lock Spring: Schritt 3, Bild 2 von 2
    • To put on the spring, insert it onto the bar.
    • If your strap lock was not locking even though it had the spring, you can increase your springs effectiveness by stretching it out a moderate amount.
  4. Repairing the Proline Guitar Strap Lock Spring: Schritt 4, Bild 1 von 3 Repairing the Proline Guitar Strap Lock Spring: Schritt 4, Bild 2 von 3 Repairing the Proline Guitar Strap Lock Spring: Schritt 4, Bild 3 von 3
    • Once the spring is on, reassemble your strap lock by inserting the locking mechanism into the underside of the housing.
    • Then, screw back on the ball cap.
Abschluss
Your strap lock should now function well, but make sure to hand test the locking strength before using your guitar. As for the replacement spring, it is hard to buy a spring of this size individually. The dimensions of the spring are approximately as follows:
Inner Diameter: 4.5 mm (.177 in)
Outer Diameter: 5.3 mm (.209 in)
Free Length: 7.8 mm (.307 in)
As stated in step 2, if you cannot get a spring of this exact size, it is possible to cut a spring from a pen to length, and with a little stretching get it to the right dimensions.
Justin Smith
121 Reputation
1 Anleitung geschrieben
Cal Poly, Team 30-4, Green Spring 2015 Mitglied von Cal Poly, Team 30-4, Green Spring 2015
CPSU-GREEN-S15S30G4
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 688
