Zum Hauptinhalt wechseln
Replace "Wings" Without Breaking Open a Magsafe Charger Technique
Was du brauchst
  1. Replace "Wings" Without Breaking Open a Magsafe Charger Technique, Replace "Wings" Without Breaking Open a Magsafe Charger Technique: Schritt 1, Bild 1 von 1
    • Use the pliers to scratch a groove wide enough for the pin to travel in to the hole where the wings pin will fit.
    • The trick is not to make it to deep so the pin can easily come back out of the hole. Start of shallow and go deeper if required.
  2. Replace "Wings" Without Breaking Open a Magsafe Charger Technique: Schritt 2, Bild 1 von 2 Replace "Wings" Without Breaking Open a Magsafe Charger Technique: Schritt 2, Bild 2 von 2
    • Insert one side of the wings pin into its hole at an angle.
    • Now, Line up the other pin with the groove and push slide it until the pin clips back into it's hole. You may need to make the groove slightly deeper if it doesn't want to go in, as we don't want to break the pin off! The tighter the fit the better. The wing will snap back into its hole and be back to normal functionality.
  3. Replace "Wings" Without Breaking Open a Magsafe Charger Technique: Schritt 3, Bild 1 von 1
    • The wings should now be in place as working as intended.
Ziellinie
3 weitere Personen haben diese Anleitung absolviert.
livfe
7.016 Reputation
21 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 32
Insgesamt: 455
