Einleitung
This replacement guide provides detailed steps on how to install a privacy doorknob. The procedure is prepared in a manner that is easy to comprehend for people with minimal to no experience in making household replacements. This is demonstrated through the use of language that is easy to understand and photos. The guide shows the removal process of a passage doorknob and installation of a privacy doorknob.
Was du brauchst
Using a Phillips #2 screwdriver, remove the two screws from the passage doorknob.
Grab the new latch that comes with the privacy doorknob set and ensure the flat side is facing away from the closing direction of the door.
Insert the new latch into the designated latch hole after figuring out the correct way to face it.
Begin tightening the 19.05 mm flat head screws that come with the privacy doorknob set to secure the latch mechanism in place.
Grab the exterior knob and align it with the holes of the latch and push it in from the side of the door that is outside your room.
Align the holes of the interior knob with the spindle as shown in the second image.
Ensure the lock and and spindle are in a vertical position.
Push the interior knob in until both sides of the knob connect.
Insert the 38.1mm flat head machine screws through the two holes of the interior knob and tighten until the doorknob is secured.
If you would like to revert to the passage doorknob, use the same steps as the ones provided to do so.
