Einleitung
Use this guide only for GHD Classic V, Mini and Max when they are unresponsive.
Was du brauchst
Remove the two plastic hinge covers located on each side of the ghd by using a thin and flat spudger.
Slowly lift the fuse and cut the two cables with your wire cutter.
You can now remove the fuse from its compartment as well as the two cables by pulling on them towards the front.
Start by inserting your new fuse's cables and let about a centimeter of slack.
Insert the end of the fuse.
Pull on both cables outward to completely fit the fuse in its compartment.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
3 Kommentare
Thanks for this! I am searching for a suitable fuse replacement, will this one work?
TB05-BB5D-145 (up to 160°C)
Bonjour, non ce fusible thermique n'est pas compatible, la température de déclenchement n'est pas la bonne, de plus la taille de celui-ci est trop large et le branchement ne comporte pas les deux connecteurs.
Si vous avez besoin du modèle correct, veuillez nous contacter ici: https://caplou.com
Belle journée
L'équipe Caplou
Parfait merci beaucoup il re fonctionne !!!
