Was du brauchst
Remove the battery and the mandrel. Loosen the screws with a T10 bit or a T10 screwdriver.
Remove the protective cover from the new Gearbox and then assemble it to the engine while respecting the demers. Reposition the LEDs if necessary.
To reassemble your device, follow the instructions in reverse order.
100%
HelloMacOS hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
