Was du brauchst
Remove the battery and the mandrel. Loosen the screws with a T10 bit or a T10 screwdriver.
Remove the top shell. Remove the battery connecter, the switch, the Engine + Gearbox assembly and then the LEDs. Detach the Engine from the Gearbox.
Install the Engine + Gearbox assembly, the Switch and then the battery cover. Reposition the wiring.
To reassemble your device, follow the instructions in reverse order.
100%
HelloMacOS hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
