Einleitung
This guide will show you how to remove or replace the motherboard on the Xiaomi Redmi Note 7 Pro. You will need some replacement adhesive to reattach the components when you reassemble the device.
Before you begin, switch off your phone.
Heat your phone to about 195 degrees Fahrenheit (90 C).
Lift the back cover to create a gap between the glass and the frame.
Insert an opening pick into the gap.
Start sliding the opening pick from the lower left corner along the side of the device to cut the adhesive
Leave the opening pick in the side to prevent the adhesive from resealing.
Lift the cover open like a book, but be careful to make sure you do not damage the flex cable while it’s still connected.
Using a screwdriver (1.5 mm ), unscrew 4 screw and remove the bracket holding the connector.
18 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
