Einleitung
Your motherboard is no longer working? This is a real shame, but you have the chance to be on this tutorial that will guide you through the process of replacing it.
Was du brauchst
Pop the center cover open on the bottom cover.
Remove the center screw with a #00 Phillips screwdriver.
Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
After the back panel has been removed, disconnect the battery to prevent electrical shock
Once all the screws have been removed the battery is now safe to extract
Close the laptop, flip the laptop over, and pop off the back small panel with a flathead screwdriver. The panel will be hanging by the hinges once open.
Use a T5 Torx screwdriver to remove the screws along the edge of the bottom cover.
Open the center cover and use a Phillips #00 screwdriver to remove single screw.
Disconnect the battery to prevent electrical shock.
Disconnect yellow-colored ribbon cable from its port which sits at the bottom left of the fan housing.
Use a Phillips #00 screwdriver to loosen the screws that secure the heat sink's heat spreader.
Disconnect the two wires from the WiFi card. You can do this with a pair of pliers or your fingernail.
Remove the screw with a #00 Phillips screwdriver.
Now remove your WiFi card to replace it.
Remove the hard disk from its location.
Remove the connector with a pair of pliers or your fingernail.
Remove the screws with a #00 Phillips screwdriver.
Remove the card afterwards.
Disconnect the various connections from the motherboard.
Carefully turn the motherboard over to disconnect the tablecloth from the keyboard.
You can now replace the motherboard.
To reassemble your device, follow the instructions in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
100%
Schwarzer hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
