Zum Hauptinhalt wechseln
Replacement of the ventirad on the Dell XPS 13 9380
Was du brauchst
  1. Replacement of the ventirad on the Dell XPS 13 9380, Remove the back panel: Schritt 1, Bild 1 von 3 Replacement of the ventirad on the Dell XPS 13 9380, Remove the back panel: Schritt 1, Bild 2 von 3 Replacement of the ventirad on the Dell XPS 13 9380, Remove the back panel: Schritt 1, Bild 3 von 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Torx T5 driver to unscrew the eight screws securing the back panel.
    • Use a spudger to pry up and loosen the back panel.
    • Lift the back panel up slightly from the non-hinged edge.
    • Pull the back panel away from the hinged edge, wiggling it back and forth to loosen the clips.
    • When the back panel clips are free, remove the back panel.
  2. Replacement of the ventirad on the Dell XPS 13 9380, Remove the battery: Schritt 2, Bild 1 von 2 Replacement of the ventirad on the Dell XPS 13 9380, Remove the battery: Schritt 2, Bild 2 von 2
    • Disconnect the cable from the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the four screws (M2 x 2) securing the battery.
    • Remove the screw (M1.6 x 4) securing the battery.
    • Remove the battery from its recess.
  3. Replacement of the ventirad on the Dell XPS 13 9380, Remove the ventirad: Schritt 3, Bild 1 von 1
    • We removed or disconnected the battery to avoid any electrical discharge.
    • To ensure maximum processor cooling, do not touch the heat transfer areas of the ventirad. Grease on the fingers can reduce the heat transfer capabilities of the thermal paste
    • 1- Remove the 4 screws (M2x3) that attach the ventirad to the motherboard.
    • 2- Lift the ventirad and remove it from the motherboard.
Abschluss
To reassemble your device, follow the instructions in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
fr en
100%
Schwarzer hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Schwarzer
5.069 Reputation
13 Anleitungen geschrieben
i.Fixit FR Team Mitglied von i.Fixit FR Team
Community
3 Mitglieder
40 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 19
Insgesamt: 1,351
