Einleitung
Your WiFi card no longer works and you want to change it. You've come to the right place, this tutorial is for you.
Was du brauchst
Pop the center cover open on the bottom cover.
Remove the center screw with a #00 Phillips screwdriver.
Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
After the back panel has been removed, disconnect the battery to prevent electrical shock
Once all the screws have been removed the battery is now safe to extract
Disconnect the two wires from the WiFi card. You can do this with a pair of pliers or your fingernail.
Remove the screw with a #00 Phillips screwdriver.
Now remove your WiFi card to replace it.
To reassemble your device, follow the instructions in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
100%
Schwarzer hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
