Einleitung
This guide will take you step-by-step on how to replace your buttons.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Before disassembling your Atari Lynx, be sure the device is powered off.
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  5. Remove the control panel by pinching the sides with your fingers and lifting  it away from the Atari.
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  6. If you want to replace the buttons other than the D-pad, you can pull them up by pinching the sides with your fingers and lifting away from front panel of Atari.
    • If you want to replace the buttons other than the D-pad, you can pull them up by pinching the sides with your fingers and lifting away from front panel of Atari.
  7. To remove the D-Pad, remove three 10 mm Phillips #0 screws surrounding the D-Pad. The buttons should fall out once the screws have been removed.
    • To remove the D-Pad, remove three 10 mm Phillips #0 screws surrounding the D-Pad.
    • The buttons should fall out once the screws have been removed.
Abschluss
Tyler Williams
317 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 1-42, Maness Winter 2014 Mitglied von Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Mitglieder
8 Anleitungen geschrieben
Thanks for the guide. The title photo shows a Lynx II, however, while all the detailed instructions are for the original Lynx (I) which is built differently.
It would be great to have a Lynx II disassembly and MOSFET Q12 replacement guide.
Siegfried Lenz - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 1,238
