Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Follow the steps in this guide to replace your broken central fan in your projector.
  1. Be certain that the projector is powered off before beginning disassembly.
    • Be certain that the projector is powered off before beginning disassembly.
    • Remove the five Phillips screws on the bottom of the projector.
  2. Remove the Phillips screw on the back of the projector.
    • Remove the Phillips screw on the back of the projector.
  3. Remove the four lock screws.
    • Remove the four lock screws.
    • You may need to use pliers at first if the lock screws are too hard to twist with your fingers.
  4. Pry the sides of the case off using your fingers. Do not pull too hard on the sides because you may break the speaker wires attached to them.
    • Pry the sides of the case off using your fingers.
    • Do not pull too hard on the sides because you may break the speaker wires attached to them.
    • Pop the tabs connecting the rest of the case together by running your fingers underneath the edges.
  5. Remove the metal plate covering the circuit board by removing the four Phillips screws.
    • Remove the metal plate covering the circuit board by removing the four Phillips screws.
  6. Unplug the six cables by gently pulling up on the cable's connector.
    • Unplug the six cables by gently pulling up on the cable's connector.
    • Avoid pulling on the connector attached to the board as you may accidentally tear it off.
  7. iPhone LCD Display Fix Kits
    Die Budgetoption, abgedeckt durch unsere lebenslange Garantie.
    Kits kaufen
    Reduziere die Reparaturkosten, nicht die Qualität.
    Kits kaufen
  8. Remove the two fans.
    • Remove the two fans.
  9. Remove the single Phillips screw on the circuit board. Gently pull up on the circuit board to remove it.
    • Remove the single Phillips screw on the circuit board.
    • Gently pull up on the circuit board to remove it.
    • The circuit board still has a few connections to other circuit board underneath it. Don't worry about these as they will disconnect as you lift up on the circuit board.
  10. Remove the four Phillips screws. The yellow arrow points to the location of the fourth screw which can be seen in the second picture.
    • Remove the four Phillips screws.
    • The yellow arrow points to the location of the fourth screw which can be seen in the second picture.
  11. Remove the two Phillips screws. The screw on the left is between two tall pieces of plastic which can make it difficult to see.
    • Remove the two Phillips screws.
    • The screw on the left is between two tall pieces of plastic which can make it difficult to see.
    • Lift the black plastic casing around the light bulb up out of the projector.
  12. Disconnect the power supply from the light bulb by gently pulling on the two metal tabs attached to it. Disconnect the power supply from the light bulb by gently pulling on the two metal tabs attached to it.
    • Disconnect the power supply from the light bulb by gently pulling on the two metal tabs attached to it.
  13. Remove the three screws circled in red that are holding the heat sink to the bottom part of the case. Remove the three screws circled in red that are holding the heat sink to the bottom part of the case.
    • Remove the three screws circled in red that are holding the heat sink to the bottom part of the case.
  14. Lift the lens/light bulb combo out of the case.
    • Lift the lens/light bulb combo out of the case.
    • It is necessary to remove the lens/light bulb combo in order to have easy access to the central fan.
  15. Remove the Phillips screw. Slide the plastic piece on the left side of the fan out of its position.
    • Remove the Phillips screw.
    • Slide the plastic piece on the left side of the fan out of its position.
  16. Remove the two screws. Lift the fan out of the case.
    • Remove the two screws.
    • Lift the fan out of the case.
  17. Remove the two connectors holding the fan to the metal frame. Insert a flat head screw driver or other prying tool under the head of the connector and gently pry up. Insert the new fan in place of the old one.
    • Remove the two connectors holding the fan to the metal frame.
    • Insert a flat head screw driver or other prying tool under the head of the connector and gently pry up.
    • Insert the new fan in place of the old one.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Dante Mazzanti
563 Reputation
3 Anleitungen geschrieben
Excellent work. I followed all the steps.
desarrollohumano - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 5
Letzten 7 Tage: 11
Letzten 30 Tage: 31
Insgesamt: 3,283
