Zum Hauptinhalt wechseln
Replacing Creative Zen X-Fi Battery
Was du brauchst
  1. Replacing Creative Zen X-Fi Battery, Detaching Front Case: Schritt 1, Bild 1 von 3 Replacing Creative Zen X-Fi Battery, Detaching Front Case: Schritt 1, Bild 2 von 3 Replacing Creative Zen X-Fi Battery, Detaching Front Case: Schritt 1, Bild 3 von 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Battery, Rubber Button Cover: Schritt 2, Bild 1 von 1
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Battery, Button Input Chip Part 1: Schritt 3, Bild 1 von 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Battery, Button Input Chip: Schritt 4, Bild 1 von 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Replacing Creative Zen X-Fi Battery, Access Midsection Plate: Schritt 5, Bild 1 von 1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Replacing Creative Zen X-Fi Battery, Unscrew below Button Chip: Schritt 6, Bild 1 von 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Replacing Creative Zen X-Fi Battery, Unscrew below LCD Screen: Schritt 7, Bild 1 von 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Replacing Creative Zen X-Fi Battery, Separating the Battery: Schritt 8, Bild 1 von 1
    • Use a spudger to pry the battery from the midsection plate.
    • There is adhesive glue underneath the battery, so additional force might be required to separate the battery.
  9. Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: Schritt 9, Bild 1 von 2 Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: Schritt 9, Bild 2 von 2
    • Locate the soldering joint connecting the battery wires to the power supply, marked by the letters "PS" on the motherboard.
    • Hold the battery wires in place so that access to the soldering joints is not blocked.
    • When using a soldering iron, keep your hands and fingers as far as possible from the iron's tip to avoid burning your skin.
    • Using a soldering iron, melt the solder connecting the red wire to the motherboard. Do the same action to the black wire.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Westley Courchene
3.314 Reputation
14 Anleitungen geschrieben
USF Tampa, Team 1-1, Remmell Fall 2015 Mitglied von USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 59
Insgesamt: 5,061
