Zum Hauptinhalt wechseln
Replacing Creative Zen X-Fi Midsection Plate
Was du brauchst
  1. Replacing Creative Zen X-Fi Midsection Plate, Detaching Front Case: Schritt 1, Bild 1 von 3 Replacing Creative Zen X-Fi Midsection Plate, Detaching Front Case: Schritt 1, Bild 2 von 3 Replacing Creative Zen X-Fi Midsection Plate, Detaching Front Case: Schritt 1, Bild 3 von 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Midsection Plate, Rubber Button Cover: Schritt 2, Bild 1 von 1
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Midsection Plate, Button Input Chip Part 1: Schritt 3, Bild 1 von 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Midsection Plate, Button Input Chip: Schritt 4, Bild 1 von 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Replacing Creative Zen X-Fi Midsection Plate, Access Midsection Plate: Schritt 5, Bild 1 von 1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Replacing Creative Zen X-Fi Midsection Plate, Unscrew below Button Chip: Schritt 6, Bild 1 von 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Replacing Creative Zen X-Fi Midsection Plate, Unscrew below LCD Screen: Schritt 7, Bild 1 von 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
Abschluss
Westley Courchene
3.314 Reputation
14 Anleitungen geschrieben
USF Tampa, Team 1-1, Remmell Fall 2015 Mitglied von USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 4
Insgesamt: 109
