Zum Hauptinhalt wechseln
Einleitung
The motherboard controls all the functionality of the device and is the major components everything else is connected to.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a spudger, wedge the tip between the front and back case to pry them apart. Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together. Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. The black rubber button pad can be removed by simply picking it up.
    • The black rubber button pad can be removed by simply picking it up.
  3. Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Lift open the LCD screen and button input chip to access the entire midsection plate.
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Lift the right edge of the motherboard off the back case. Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
    • Lift the right edge of the motherboard off the back case.
    • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Westley Courchene
3.251 Reputation
14 Anleitungen geschrieben
USF Tampa, Team 1-1, Remmell Fall 2015 Mitglied von USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 338
