Zum Hauptinhalt wechseln
Replacing Crosley CR704 Needle
Was du brauchst
  1. Replacing Crosley CR704 Needle, Needle: Schritt 1, Bild 1 von 1
    • With steady hands, gently tug the needle from its cartridge pulling downwards.
    • There will be a slight resistance.
  2. Replacing Crosley CR704 Needle: Schritt 2, Bild 1 von 1
    • Secure the new needle by gently snapping it upwards an inwards until it clicks into place.
    • Be careful not to touch the stylus tip when handling the tone arm. This is what plays your records.
Abschluss
Test by playing a record. We suggest "Revolver" by the Beatles.
MarkAnthony
772 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 Mitglied von UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G4
3 Mitglieder
Ein Kommentar
2 steps with the same pic for both.
Really?
John Pottle - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 43
Insgesamt: 18,059
