Zum Hauptinhalt wechseln
Replacing IBM ThinkPad 560z Speaker
Was du brauchst
  1. Replacing IBM ThinkPad 560z Speaker, Battery Removal: Schritt 1, Bild 1 von 1
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
  2. Replacing IBM ThinkPad 560z Speaker, Upper Case: Schritt 2, Bild 1 von 1
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  3. Replacing IBM ThinkPad 560z Speaker: Schritt 3, Bild 1 von 2 Replacing IBM ThinkPad 560z Speaker: Schritt 3, Bild 2 von 2
    • Open the flap on the left hand side.
  4. Replacing IBM ThinkPad 560z Speaker: Schritt 4, Bild 1 von 2 Replacing IBM ThinkPad 560z Speaker: Schritt 4, Bild 2 von 2
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  5. Replacing IBM ThinkPad 560z Speaker: Schritt 5, Bild 1 von 2 Replacing IBM ThinkPad 560z Speaker: Schritt 5, Bild 2 von 2
    • Open the flap on the right side.
  6. Replacing IBM ThinkPad 560z Speaker: Schritt 6, Bild 1 von 1
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  7. Replacing IBM ThinkPad 560z Speaker: Schritt 7, Bild 1 von 2 Replacing IBM ThinkPad 560z Speaker: Schritt 7, Bild 2 von 2
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  8. Replacing IBM ThinkPad 560z Speaker: Schritt 8, Bild 1 von 1
    • Use your fingers or a spudger to detach the connector.
  9. Replacing IBM ThinkPad 560z Speaker: Schritt 9, Bild 1 von 2 Replacing IBM ThinkPad 560z Speaker: Schritt 9, Bild 2 von 2
    • Carefully lift and remove the keyboard.
  10. Replacing IBM ThinkPad 560z Speaker, Speaker: Schritt 10, Bild 1 von 2 Replacing IBM ThinkPad 560z Speaker, Speaker: Schritt 10, Bild 2 von 2
    • Slowly and carefully lift the speaker with your fingers.
    • The port that the speaker plugs into can be easily removed from the motherboard if not careful! Unplug the speaker with extreme caution!
  11. Replacing IBM ThinkPad 560z Speaker: Schritt 11, Bild 1 von 2 Replacing IBM ThinkPad 560z Speaker: Schritt 11, Bild 2 von 2
    • Use your fingers to unplug the wires from the connector.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 26-27, Regan Spring 2010 Mitglied von Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,740
