Zum Hauptinhalt wechseln
Replacing Motorola V60i Logic Board
Was du brauchst
  1. Replacing Motorola V60i Logic Board, Battery: Schritt 1, Bild 1 von 2 Replacing Motorola V60i Logic Board, Battery: Schritt 1, Bild 2 von 2
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Replacing Motorola V60i Logic Board: Schritt 2, Bild 1 von 2 Replacing Motorola V60i Logic Board: Schritt 2, Bild 2 von 2
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Replacing Motorola V60i Logic Board, Back Plate: Schritt 3, Bild 1 von 1
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Replacing Motorola V60i Logic Board: Schritt 4, Bild 1 von 2 Replacing Motorola V60i Logic Board: Schritt 4, Bild 2 von 2
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Replacing Motorola V60i Logic Board: Schritt 5, Bild 1 von 1
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
  6. Replacing Motorola V60i Logic Board, Motherboard: Schritt 6, Bild 1 von 1
    • Gently lift logic board from back plate.
  7. Replacing Motorola V60i Logic Board: Schritt 7, Bild 1 von 2 Replacing Motorola V60i Logic Board: Schritt 7, Bild 2 von 2
    • Place logic board on front cover.
    • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
Abschluss
Cal Poly, Team 30-40, Garner Spring 2010 Mitglied von Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
Quero comprar esse aparelho, alguém tem para vender?
Karison Mesquita - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 2,169
