Einleitung
This guide will walk you through removing and replacing the Nintendo DS battery.
Ersatzteile
Remove the cartridge from the console.
Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
Remove the battery door.
Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic open tool or spudger isn't available, your fingernails may work.
Make sure to press the power button on the Nintendo DS when finished to confirm the battery is working.
6 weitere Nutzer haben diese Anleitung absolviert.
