Zum Hauptinhalt wechseln
Replacing Nokia Classic 2600c-2b Faceplate
Was du brauchst
  1. Replacing Nokia Classic 2600c-2b Faceplate, Faceplate: Schritt 1, Bild 1 von 2 Replacing Nokia Classic 2600c-2b Faceplate, Faceplate: Schritt 1, Bild 2 von 2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Replacing Nokia Classic 2600c-2b Faceplate: Schritt 2, Bild 1 von 1
    • Remove the back cover to expose the battery.
  3. Replacing Nokia Classic 2600c-2b Faceplate: Schritt 3, Bild 1 von 2 Replacing Nokia Classic 2600c-2b Faceplate: Schritt 3, Bild 2 von 2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
  4. Replacing Nokia Classic 2600c-2b Faceplate: Schritt 4, Bild 1 von 2 Replacing Nokia Classic 2600c-2b Faceplate: Schritt 4, Bild 2 von 2
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
  5. Replacing Nokia Classic 2600c-2b Faceplate: Schritt 5, Bild 1 von 1
    • Remove the faceplate with the number pad attached.
  6. Replacing Nokia Classic 2600c-2b Faceplate: Schritt 6, Bild 1 von 1
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
    • Apply new faceplate.
    • Follow the instructions in reverse order to reassemble the phone.
Abschluss
Ian VanZandt
654 Reputation
5 Anleitungen geschrieben
James Madison, Team 3-1, Klein Spring 2012 Mitglied von James Madison, Team 3-1, Klein Spring 2012
JMU-KLEIN-S12S3G1
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 396
