1. Before disassembling your phone, be sure it is powered off. To remove the back cover press the two "buttons". Remove the battery.
    • Before disassembling your phone, be sure it is powered off.
    • To remove the back cover press the two "buttons".
    • Remove the battery.
  2. Remove the three 3mm black screws on the top of the phone. Remove the two 5mm screws.
    • Remove the three 3mm black screws on the top of the phone.
    • Remove the two 5mm screws.
    • Loosen these two screws at the bottom of the phone.
      • Probably these screws will not come out from their home, no matter. It is only important to unscrew them completely.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. With a plastic opening tool remove the little piece of plastic in the bottom of of the phone. The two corners marked are VERY SLENDER, when removing the plastic be very careful. Otherwise you will break them. To remove the logic board assembly push from the rear of the phone.
    • With a plastic opening tool remove the little piece of plastic in the bottom of of the phone.
      • The two corners marked are VERY SLENDER, when removing the plastic be very careful. Otherwise you will break them.
    • To remove the logic board assembly push from the rear of the phone.
  5. Remove the keyboard with a plastic opening tool. Remove the keyboard with a plastic opening tool.
    • Remove the keyboard with a plastic opening tool.
Abschluss
11 weitere Nutzer haben diese Anleitung absolviert.
Matteo Moro
476 Reputation
1 Anleitung geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 25
Insgesamt: 4,244
