Einleitung
I will be providing clear and easy steps on how to replace your Battery/Memory Card Cover Lock on your digital camera with out having to buy another one.
Was du brauchst
Turn the camera so the bottom is facing upwards.
First pull open latch to expose two screws covering lock.
Use your Phillips #00 screwdriver and unscrew both screws.
Turn latch over.
There will be one screw visible holding down the cover.
Unscrew single screw with your Phillips #00 screwdriver.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
After unscrewing the screw you will see a single spring.
Make sure spring is in place to be able to close lock properly.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
