Einleitung
A guide to remove power block from the Sega Dreamcast.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Verify that the console is disconnected from the AC outlet before you begin. Flip the console over on its back.
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  6. Verify that the console is disconnected from the AC outlet before you begin. If you have just powered off the system, give the capacitors a few minutes to discharge before you begin working. Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
    • Verify that the console is disconnected from the AC outlet before you begin. If you have just powered off the system, give the capacitors a few minutes to discharge before you begin working.
    • Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
  7. Remove the two 10mm Philips #02 screws that are fastened to the power block.
    • Remove the two 10mm Philips #02 screws that are fastened to the power block.
  8. Do not bend the male pin header between the mounted head when you remove the power supply from the chassis. Remove the power board by using both hands to gently lift the power board away from the console.
    • Do not bend the male pin header between the mounted head when you remove the power supply from the chassis.
    • Remove the power board by using both hands to gently lift the power board away from the console.
  9. Remove the clear plastic film that is tucked between the power supply and the chassis.
    • Remove the clear plastic film that is tucked between the power supply and the chassis.
Abschluss
8 weitere Nutzer haben diese Anleitung absolviert.
wkwong
426 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 5-1, Regan Fall 2009 Mitglied von Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Mitglieder
18 Anleitungen geschrieben
All symptoms of dead PSU can be occuring, if by accident flat ribbon cable between motherboard and controller board is disconnected. Check that cable if both ends is firmly plugged.
lauraiss lv - Antwort
Hello There!
i turn on my dreamcast, No video, GD don´t spin, but the orange led barely shine, this happened many years ago (2003) , i just bought another DC in those days because i was in a hurry to end Grandia 2, and now i still have the damaged console in my room and im wondering if it is possible to fix it ...thanks!
Mardito Online - Antwort
Very good and Panico
Mikesin - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 3
Letzte 7 Tage: 23
Letzte 30 Tage: 75
Insgesamt: 11,934
