Zum Hauptinhalt wechseln
Replacing Strings on a Mandolin
Was du brauchst
  1. Replacing Strings on a Mandolin, Mandolin Strings: Schritt 1, Bild 1 von 1
    • Place the mandolin on a firm, level surface with adequate lighting.
  2. Replacing Strings on a Mandolin: Schritt 2, Bild 1 von 1
    • Loosen the tuning nob.
    • Carefully remove the top end of string from the tuner in the mandolin head.
  3. Replacing Strings on a Mandolin: Schritt 3, Bild 1 von 1
    • Unhook the old string from the tail of the mandolin.
    • Remove the string from the bottom.
  4. Replacing Strings on a Mandolin: Schritt 4, Bild 1 von 1
    • Select a new string, and then insert the bottom end of it through the bridge at the tail.
  5. Replacing Strings on a Mandolin: Schritt 5, Bild 1 von 1
    • Secure the string to the tail by looping it over the hook.
  6. Replacing Strings on a Mandolin: Schritt 6, Bild 1 von 1
    • Pulling the string taut, bring its top end across the nut and into the tuning peg.
  7. Replacing Strings on a Mandolin: Schritt 7, Bild 1 von 1
    • Run the line through the tuning element at the head of the mandolin, as pictured. Be sure to pull the string away from the headstock.
  8. Replacing Strings on a Mandolin: Schritt 8, Bild 1 von 2 Replacing Strings on a Mandolin: Schritt 8, Bild 2 von 2
    • Pull the string down, towards the fretboard, and run the string underneath itself.
    • Pull the string tight so that it wraps around the tuning peg.
  9. Replacing Strings on a Mandolin: Schritt 9, Bild 1 von 1
    • Pinch the string over itself to create a knot.
  10. Replacing Strings on a Mandolin: Schritt 10, Bild 1 von 1
    • Tighten the tuning nob until the desired tension is reached.
  11. Replacing Strings on a Mandolin: Schritt 11, Bild 1 von 1
    • Clip off any excess string.
  12. Replacing Strings on a Mandolin: Schritt 12, Bild 1 von 1
    • Optional: Clip the electronic tuning device to the head of the mandolin; use the device to assist in fine-tuning your mandolin.
  13. Replacing Strings on a Mandolin: Schritt 13, Bild 1 von 1
    • Commence rocking on with your Gretsch New Yorker!
Ziellinie
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Drew
125 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 19
Insgesamt: 7,448
