Einleitung
The PODZ port is located on the back face of the Ion Air Pro. This port allows the WI-Fi PODZ Pack accessory to be installed.
Was du brauchst
Remove the 6 screws securing the lens cover bezel using a #00 Phillips screwdriver. This will allow you to remove the bezel and lens cover.
Remove the metal camera body cover by sliding it toward the lens end of the camera.
Remove 2 screws on the bottom of the camera body using a #00 Phillips screwdriver.
Remove the 3 screws that secure the camera to the body using a #00 Phillips screwdriver.
Remove the 8 screws around the perimeter of the back cover.
Remove the 2 screws in the PODZ port.
Slide PODZ port out of the camera body.
Disconnect ribbon cable from the back of the PODZ port.
Ein Kommentar
How do you reconnect the ribbon cable to the back of the PODZ port when you reassemble?
